Auto dimming not working properly
  • 3
Wascalwabbit
I just installed a pioneer deh-x6800bt in a kenworth t800. I tested the pwr gnd ctrl and dim wires before wiring in the harnesses. Dim read the way I had expected it to, lowering in voltage as I turned the dim setting down, so I figured it works as intended. Now I have the stereo in and when I set the dim options to auto sync only one thing happens: If I turn the headlights on and the panel lights all the ways down the illumination goes to full brightness. All other combinations dim. I'll retest the dim wire when I have a chance and post the results, unless someone already knows how tonfix this.
Thanks
i watched https://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/How+To+-+DEH-X6800BT+-+Color,+Illumination+and+Dimmer and it seems like thats the way it is supposed to work, i dont think the digital 1-10 brighness settings will increase or decrease with the variable analog potentiometer that you use for normal dash lights. If it senses a voltage change on the dimmer wire like when you turn on the headlights it will go into dim mode. i think the lowest setting on your cars dimmer is not enough of a voltage change on the dimmer wire for the head unit to realize it should change to dim mode.
Thanks for the reply. I did watch that video as well, and my expectation was not that the lights of the head unit would dynamically get brighter/dimmer. Its just that I would expect the radio to go from the bright mode to the dim mode when I dim my dash lights, but it actually does the exact opposite.
Usually if you apply 12vs to the orange wire the radios will dim about 50% ..on some of the older radios ..they would sometimes illuminate additional backlighting for the controls ..like presets and such and not effect the display
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
Ugh yeah it can use Android Auto and Google Maps says so right in the manual. Alpine is good about that stuff with integrating not only ugh Apple...
Wascalwabbit
Wascalwabbit
North dakota
Louisiana_CRX
