Audsion LRX 6.9
martinezl907
chicago
Audison Lrx 6.9
Trade for Audison Bit one
Used but In very good condition
550 Shipped
http://imageshack.com/a/img538/9955/nUXkYX.jpg
http://imageshack.com/a/img673/875/GnJUqf.jpg
http://imageshack.com/a/img673/801/YfrlwF.jpg
http://imageshack.com/a/img540/8586/Hb0G3a.jpg
tempted to consider a swap for my Hertz ML3000 in a custom enclosure. But i really like the sub and don't have an immediate need for the amp, my LRx5.1k does what i currently need.
awesome amp here. fantastic build quality. the amp is worth $1k.
For those not aware, this amp is designed to let you run active with amazing SQ. This amp can power a 3-way active front stage with its on-board crossovers. You can run active with a 2-way and power a 1 ohm sub. You can run passive front and rear and power a sub. You can run active fronts and passive rears. Very flexible.
http://www.audison.eu/download.php?file=assets/p_1315389321_audison_LRx6_9_tech_EN.pdf&name=lrx_6.9_tech_sheet_tech_sheet
A Channels: 50-5,000Hz HPF
B Channels: 50-5,000Hz HPF + 250-5,000Hz LPF (bandpass capable)
C Channels: 50-1,000Hz LPF + subsonic filter and adjustable slope
LRx 6.9 Power Output
Load Imp.------6 Channels-------5 Channels--------4 Channels---------3 Channels---
4 Ohm--------4x70+2x75W-----4x70+1x280W------------------------2x240+1x280W
2 Ohm--------4x120+2x140W---4x120+1x470W-------------------------------------
4/2 Ohm-----------------------4x70+1x480W------2x240+2x140W----2x240+1x470W
4/1 Ohm------------------------------------------2x240+2x230W------------------
2/1 Ohm------4x120+2x230W------------------------------------------------------
martinezl907
martinezl907
chicago
HOTT_SINCE_81
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
