AudioControl LC2i Install Help
  • 3
zyklonb
new york
I have my audiocontrol LC2i coming in the mail today im just a little bit confused as to where i am going to be running power to the unit from and also where i am going to be getting a remote signal from. I am familiar with aftermarket head units but ive never used a line out product before. I know ill be able to tap into the speaker signals from the rear speakers but thats about as much as i know. Any help on installing the product would be greatly appreciated.
Install is going in a Subaru Legacy
the LC2i can generate a remote turn-on itself to use to signal the amp to turn on. power can come from the amp power connections.
that's the easy way to do it - and mount it next to the amp.
Hello zyklondb -
Tapping into your rear speaker signals for the LC2i will be fine. You will need separate power and ground, preferably a direct connection to the battery. We don't generally recommend sharing power with other components. The GTO Signal Sense will act as a trigger, so you will not need to source a trigger from your factory head unit or accessory.
Once the unit is installed, you can refer to our level matching video on youtube - search for "AudioControl, Level Matching".
Regards,
AudioControl
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
729
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
zyklonb
zyklonb
new york
zyklonb
