audio cutting out
  • 5
jeep_poundin
Indiana
had a dual dvd head unit and though it was the problem. went and bought a sony head unit and its still giving me problems. i have 3 amps, 2 bridged for subs and one for audio. when its playing, the audio will randomly cut out but the bass still plays. idk whats causing it to do this. i have a line driver in the rca's for the subs, but i wouldnt think thats the problem
ya. all 3 grounds go to a distribution block which goes straight to the chasis. all the amps stay on. the audio just stops playing
are the head units not pushing enough power through the rca's?? i went out and checked my grounds and after its turned up to much the subs cut out also. but yet again the amps are still on.
Do you have a relay for your remote wire? 3 amps and a line driver is what I have and I had to add a relay to the remote wire because my highs amp was cutting out.
i have the remote for the sub amps running straight from the battery with a switch. so the remote from the head unit is just powering the mids and highs. i'll try that and see if it works
Restarting the phone every 1-2 days is a plus too. My moms phone is useless by the third day of not restarting. As soon as it's restarted it's fine.
11
A Link would be very helpful. Id be interested in taking a look at some gear
72
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
226
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
jeep_poundin
jeep_poundin
Indiana
jeep_poundin
