natmaned88
Arc Audio amp in perfect working condition
ADDITIONAL IMAGES
PRODUCT DESCRIPTION
If you are thinking about purchasing any ARC Audio products from the internet -CLICK HERE FIRST- to view our companies internet sales policies!
The KS amplifiers are a totally "out of the box" rethink of what an amplifier can be. By taking a proven but underutilized Pro Audio amplifier class and bringing it up to date with modern components we can achieve uncompromising sound quality in a compact chassis that makes installation in even the most challenging cars and trucks a breeze.
Switching to a higher class. Class G and Class G/H amplifiers offer the best of all possible characteristics. Power output, distortion, efficiency, heat, noise, size are all class leading specs with this design.
Why does this class or amplifier perform so well? It's built for music not test tones or noise. Class G/H works with the dynamics of music not against then. When an amplifier is playing music even at full volume, due to its dynamic nature, it is really only working above 1/2 power about 100% of the time. You only need full power during the very loud passages like the impact of a drum or the pluck of a bass string. The rest to the time your 2500 watt amp is making less then 1200 watts. That's where the KS amp's Class G/H comes in. It's like having 2 amps in one. A 400 watt amp that can be a lot smaller and makes a lot less heat that in a fraction of a second becomes an 800 watt monster. The trick of making this work is striking a balance between switching this high power section on and off. It takes the years of experience Nikola Engineering has to achieve this delicate balance.
Class H mono block subwoofer amplifier
Advanced microprocessor control system
Non digital class G/H switching design
Strapable design
Code based flashing diagnostics
Designed By Robert Zeff
Protection against: Reverse voltage, Over Voltage, Speaker Short, and Thermal Overload
Can drive highly reactive loads
Hi/Low Level balanced switchblade RCA inputs for flexible integration into most applications
Optically isolated Mosfet power supply
24dB lowpass crossover with 30Hz to 250Hz
Master/Slave control
Variable Sub Sonic filter
Variable Bass Boost
Quiet Fan cooling
PRODUCT SPECIFICATIONS
KS Amplifier Product Manual: Download Product Manual Here
1 Channel @ 4 ohms: 750 Watts
1 Channel @ 2 ohms: 1400 Watts
1 Channel @ 1 ohms: 2500 Watts
Frequency Response: 20Hz - 250Hz
Crossover Range: 30Hz - 250Hz Variable
Bass Boost: +15dB @ 45Hz
S/N Ratio: 103dB
Input Sensitivity (Low): 200mV - 3.5V
Max current draw: 210A @ 2600 Watts 2% THD
Idle Current: 1.14 Amp
Fuse: No Onboard Fuses (Recommend External Fusing)
Dimensions: 21.5" (L) x 8.0" (W) x 2.325" (H)
750 plus shipping may trade for a soundqubed 2200 and 400 cash
![](/proxy.php?image=http%3A%2F%2Fi276.photobucket.com%2Falbums%2Fkk22%2Fnatmaned%2FMobile%2520Uploads%2Fimage.jpg&hash=e2f21ddc6a7eea82def9a0907c5b458e)
ADDITIONAL IMAGES
PRODUCT DESCRIPTION
Strapable design
Variable Bass Boost
Quiet Fan cooling
S/N Ratio: 103dB
