rc10mike 10+ year member
I b sippin on sizzurp
Arc Audio 4000SE
Near perfect condition, only a few insignificant marks around the mounting feet.
# Balanced and standard inputs
# 24dB Low pass crossover (Bandwidth limiting)
# Sanken discrete bi-polar output devices
# Bass Boost is adjustable for frequency and level +15dB
# Microprocessor controlled to adjust to different ohm loads
# Dual 4" speed variable fans for reliable cooling
# Self Branded Ultra Low ESR Power Caps
# Multi power supply voltage rail system
# 1 Channels @ 4 ohms: 1200 watts
# 1 Channels @ 2 ohms: 2300 watts
# 1 Channels @ 1 ohms: 4000 watts
# Frequency Response30hz - 230hz: 4hz - 230hz
# Crossover Range (Bandwidth limiting): 30hz - 230hz
# Bass Boost: 20hz - 80hz + 15Db
# S/N Ratio (A wtg) ref 1Wall 4 ohms: 80Db
# Low Level Imput Sensitivity: 200mv - 4v
# Balanced Input Sensitivity: 400mv - 8v
# Max Peak Current 20hm Mono: 450 amps @ 1% Distortion
# Idle Current: 4 amps
# Size: 311/2 "(L)X101/4"(w) X33/8"(H)
Shipping is free within lower 48.
Arc Audio 4000SE
