another rendition of "overpower vs underpower"
pilotdog68
Omaha
i know versions of this issue are everywhere, but i want a specific answer.
what are the chances of me blowing a 10" infinity reference sub (model: 1060w, rated RMS: 275w) with a kicker dx300.2 amp (300w RMS) in a sealed box?
i dont crank my music too loud, so i thought i would be fine till i read that kicker amps are usually underrated. but then again sealed enclosures can "handle more power".
what do you experts think?
I have always run my subs at higher power than what is rated just make sure you get a close match on RMS not Peak. Don't clip the signal and it will be fine.
My buddy has two 12" Inf references in a ported box and a ~440 watt Kenwood amp, sounds good for what it is. I don't think it really likes that ported box since the impedance readings from both are at like 6 ohms so something weird happened.
Dayton Audio has a ton of affordable tweeters.
13
124
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
785
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
pilotdog68
pilotdog68
Omaha
Wingman0121
    Jun 1, 2024
    May 31, 2024
