Another reason to let your box dry.
ultimate157
Engineering Student
Well today I pulled my Pioneer Premier 106DVC out of the 0.8^3 sealed box I built because I'm going to be building a ported box for it. I noticed there was a ton of white stuff all over the magnet. I also noticed it smelled a lot like silicone, and thats what it is. I didn't let the silicone sealant dry long enough and it found its way all over the magnet:crap:
Normally I finish the box. Then I move cars around, pull wires, sweep, etc. By then the thing is dry because it takes me so **** long to clean up.
It isn't the drying you should be worried about, it's the fumes it gives off which need to clear out overnight. They eat through foam suspension parts, which obviously isn't good.
Good thing this sub has some sort of hard fiber surround and a cotton spider (at least thats what it looks to me)
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
661
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
895
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
ultimate157
Engineering Student
ultimate157
Worcester, ma
iamamp3pimp
Decebal
    Jun 10, 2024
