Another Critique my build request!!
About to come home from over seas. Wanting to redo the audio in my 2003 g35 sedan.
Metra Dash Kit
Kenwood Excelon KDC-X596 Fine
For door speakers and amp
PPI 600.2 Old or new?
Jbl ms-62 Mehhhh
And for the sub and amp
Kenwood KAC-8105D No
Dcon 12 Yes if you have enough space
How about this?
Yep
A good 4 channel would be much simpler huh?Suggestions?
If you bridge the rear channels for a DCON it would be perfect... How about that? Actually you could run a Dcon on a channel each with this beast...
Metra Dash Kit
PPI 600.2
Jbl ms-62
Kenwood KAC-8105D
Dcon 12
How about this?
This sounds pretty good. The KW should be adequate for the DCON with D4 coils and the PPI Phantom 600.2 is a very good Class D 2 ch. for the $.
Personally, I would look for a 1ohm stable sub amp that produces 500 watts rms at 4ohms though for a few bucks more. The DCON with D2 coils would be wired to 4 ohms. This would allow some flexibility in the future if you decided to add another D2 DCON for 1000w rms at 2ohms or a sub that would take more power.
Example: Audio Savings | MB Quart ONYX ONX1.1600D 1600 Watt Mono Block Car Audio Class D Amplifier/Amp
just my.02
Overall could be a pretty decent setup. Get that Dcon in a nice enclosure and you should be pretty happy with just about any of the options you listed.
just my.02
Im not using the ppi anymore, I put my latest build up on the bottom, care to take a look?
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
728
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
914
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
SnapMech
SnapMech
Oceanside,CA
SnapMech
