don't turn car on. insert fuse, then turn car on. that's how i fried my kx1200.1. i had my car on, and flipped my circuit breaker and saw smoke coming out of the amps vents. big no no.are you supposed to start up the car with everything hooked up the 1st time?
wait no. leave the fuses in the amps. make sure you place the fuse at the battery in line as well BEFORE turning on the car. DO NOT remove the fuses from your amp.so after you have everything wired through the car you take out the fuses in the amp and then turn the car on?
have + and - hooked up right?? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifoh well i didnt get what you were saying i had that fuse in already and then i started my car and everything started to flicker and i heard my amp crackling and it was smoking
