amplifier help, new to car audio.
  • 2
you won't get one cheap amp to run both speakers and subs at the power levels you want.
get two separate amps, maybe even used. check the classifieds. a 2 channel amp for the speakers should be pretty cheap. a monoblock class D for the subs will cost a bit more. you need to determine the voice coil impedance for the subs. single or dual? 2 or 4 ohm? Powerbass has some affordable amps that are decent. what vehicle is this going into? some cars require adapters and interfaces to add equipment. do you have a factory or aftermarket head unit?
don't forget an amplifier wiring kit, and paying someone who knows what they are doing to install everything. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
841
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/
6
924
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
4
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
tomistehbomb616
tomistehbomb616
pickerington
keep_hope_alive
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
