Amp Upgrade Help Please
  • 1
I have been lurking here for a while and have already learned a lot from you guys. I am about to try an install that is a little more complicated than anything else I have tried before and need som advice. I am trying to swap out the factory amp (not a Bose system) in my 2009 Cayman and need some help trying to figure out the new set-up. Current factory system has 9 speakers running on 7 channels (2-4" rear, 2-4" door, 2-7.75" mid bass woofers in door, 2 tweeters in dash, and 1 center in dash). Each speaker has its own direct wire to the amp and the tweeters have resistors on them. The door 4" and tweeter run on one channel. I also already installed a powered sub behind the seat which gives me all the bass I really want.
The factory speakers are pretty good but the amp is way underpowered. I do not plan to run the center speaker so I want to see what the best way is to run the other eight. I have looked at running a 5 channel amp (2 rears on 2 channels, 4" doors and tweets on 2 channels, and door midwoofers on one channel), but am pretty shocked at the price of a 5 channel amp that will allow me full adjustability on the 5th channel for the midwoofers (I think I need HP control and not LP on this channel).
I think my other option is running a 4 channel amp with a passive crossover (run the 4 door speakers and 2 dash tweeters on 2 channels and the 2 rears on the other 2 channels). I would install the crossovers near the amp. From what I can tell, this would be far more friendly on my pocket book since 4 channel amps are much less expensive and I would have more adjustability woith the crossovers.
Now, what am I missing and what is completely wrong with my ideas? Also, any recommendation on amps/crossovers? Im really a middle of the road guy and don't have to have the greatest and best. Thank you for the help; I obviously need it.
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
178
401
  • Locked
707
annapolis76eb
annapolis76eb
Annapolis, MD
annapolis76eb
