Amp to run these four sets??
  • 4
jeeper2269
I’m looking at running the following in a new Jeep (after recommendations from forum members)
would like to know what amp you would suggest.
Polk DB 351 (35 watts rms each speaker)
Polk DB 402 (45 watts rms each speaker)
Polk DB 652 (100 watts each speaker?)
Hertz DCX 87.3 (30 watts rms each speaker)
thanks guys.
thanks guys.
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
134
6
366
jeeper2269
jeeper2269
Somewhere, OR
jeeper2269
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
