Amp setup
  • 3
No, set the high pass to 80-100 so you don't send 80-100hz and lower to the crossover which will then send that to your mid. Your crossover will split the 80-100hz and up between your mid and tweet. You can set this at your head unit if it supports it or at your amp.
depends on what the amp does per channel and how much the speakers are rated for.
if ur speakers are rated 50 watts rms, and ur amp does 60-75 rms, set it to all.
if speakers are rated for 40 watts rms and ur amp does 100 rms per channel, u can set it around 75hz filter to be safe
I will look into the big 3 being done here pretty soon. As I said previously you guys are awsome, so thank you for everything. My alpine's came...
10
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
121
6
359
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
662
cody0707
cody0707
Tallahassee, Florida
Cruzer
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
