amp repair?
most likely db-r won't take you amp right now depending on what brand it is. They are completely swamped right now. they will however refer you to someone.
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
231
snow96
PIMP
snow96
Texas
pieper88
Decebal
    Jun 10, 2024
