amp question/help
  • 2
Bran4life
Hey everyone Im a “noobie “ to the car audio world. I have a 2011 Corolla & Google says my stock alternator runs 100 amps. Would that be enough to run an all in one enclosure sub/amp.?
or am I looking at needing upgrade my alternator.?
800w
Maximum Power RMS: 200 Watts
Impedance: 2 Ohm
800w
Impedance: 2 Ohm
You should be alright under 1,000 watts for sure. Your lights may flicker a tad on heavy bass. Shoot for 700 on bass and 300 on the mids/highs. GM-9705
757
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
Bran4life
Bran4life
Florida
Bobbytwonames
