amp powering question
unknown00
TX
i have a cadence TXA-1502 powering a 8" JLw3v3 and it is set at 300watts at 4ohms but i don't want the sub handling that much. i only want the sub getting 200-250watts...i have the input gain set half way and bass eq set at about +10 dB (max is +12 dB) with the HU bass on max. should i be fine?
so why would you recommend me adjust the gain instead of bass when i was trying to reduce power to sub? sry for the n00b questions...still confused when bass boost should be off
because with boost on, one frequency and those close to it will be louder than the rest of the range......
stupid question- how the hell do you measure voltage to sub? i just bought a dmm and i have negative at negative and positive at positive on speaker wire and it just keeps showing 0
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
859
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
193
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
389
unknown00
unknown00
TX
dman4486
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
