Amp Ohm Question/Suggestions
  • 2
Peggle
G'morrow gents,
So I know some of you are tired of seeing me post a bunch of crap, but bear with my noobiness for just a little bit longer. So my Boss PH3000D is blown and I'm now tasked with finding another amp. I seriously don't want to fk up my next purchase so I'm back here asking more questions. //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif Ok so down to the reason I'm here. I have 2 12 Rockford Fosgate P3d4 @ 600rms each and I've noticed something while looking at amps. All the amps have a rating such as
1200w rms @ 1 ohm
900w rms @ 2 ohms
600w rms @ 4 ohms
In the past I was trying to find an amp that does 1200w rms at 4 ohms but those amps run at $800-$1500 which is stupid expensive. Whenever I first started looking into a system I read that running your setup at 1 ohm generates a lot of heat thus shortening the life of the amp/subs which is why I was trying to find 1200w rms @ 4 ohms. Can someone enlighten me on what I'm missing? Would it hurt anything if I bought one of those amps that does 1200w rms @ 1 ohm?
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
It also lowers the amps efficiency and raises the current draw.
620
Thank you for your advice, everyone. I feel much more confident going forward. You guys are great (y)
17
Peggle
Peggle
Dallas, TX
basswiigee
    May 31, 2024
    May 24, 2024
