amp goes into protection mode
  • 1
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
194
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
389
6
487
Jimjam72
Jimjam72
chicago,il
Jimjam72
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
