amp getting hot
  • 4
I would check each coil on your sub with a DMM.I had a sub go bad on me last week,after banging for 8yrs,throwing my configuration into a .5 ohm,rather than the 2 ohms needed/running.I pulled my subs out ,and checked all of them on that amp,and found one to be bad.Could be your issue as well?Bad coil/coils
it only happens to me in the summer time though
Need to find a way to get some air around/under that amp, or some kind of fan on there to try cool it down,if you dont want to move it, or turn it down,about all that can be done that i can think of:crap:
check the grounds too... recheck all the wires make sure everything is solid... also check the coils and the terminals on the subs.. I had 2 leads break lastweek on me and was making my amp run warmer than normal
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
12
196
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
390
6
487
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
780
slvrado28z
slvrado28z
midland, tx
cyn
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
