amp gets really hot
The majority of heat comes from low voltage, the battery and alt not being able to produce the current being draw by the amp. The Magnum's batteries are in the rear, and that may have been there excuse for not fusing it- it's not a very long run. But, if that wire magically comes out of your amp, you car can catch fire.
Check the ground and make sure they sanded the surface down to bare metal. A couple other things that cause hot equiptment would be too small gauge of wiring, cheap amps (Sony xplodes get pretty warm) and having the wrong size amp for the sub you are running (having to run the amp at full power all the time).
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
92
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
276
Alvi45
Alvi45
Fresno,CA
Jvs
