amp doesn't run in the cold?
18lexusowner
My Jensen power 900w that I thought was shot now runs perfectly. The only thing is it only does it when it's warm out (30-40) since it's winter. When it's freezing out the amp doesn't seem to work.
Now this amp is still under warranty so do you guys think i should send it in as a defect or is that normal operation?
might be when its cold there is a little bit of shrinking and some thing loses contact in the signal path then when it warms up that very small gap is closed,,im not sure though.
ha ha, ***** for you
I sent this stupid piece of **** in to get repaired and I get it back and it's doing the exact same thing!!!
Screw Jensen amps. Prolly will turn this into a boat anchor.
Its the remote output voltage from the deck. Had the same problem a few years ago.
If it was that it would cause the amp to not turn on at all since the remote wire only sends a signal for the amp to turn on. My amp turns on but doesn't put out sound.
(to the best of my knowledge)
meh, I just think it is because it is Jensen. Want a good budget friendly amp, check into some of the cheaper maxxsonic stuff.
Yea my dad had thought jennsen was a good company to buy an amp from, but that was because he remembered back when they actually were a good company.
Mixed Mono has also been around for many years from the 80s as well. Ill use a set of 4 ohm components with a passive Xover and throw in a 4 ohm...
116
354
  • Locked
662
Amp
477
18lexusowner
18lexusowner
Phoenix, AZ
18lexusowner
    Jun 1, 2024
    May 31, 2024
