amp cutting in and out but not turning off and on
brandonsgsxr
okay so im running a crossfire bmf 1700 and i blew one of my subs so i took it out tried to sell it no one bought it so i just put it back on some spare subs, this is where the problems began. The amp was working flawlessly when i took it out, put it in a box, took it out of the box and back in the truck and now its messed up. i can be sitting still and the subs will play and then shut off for no reason then i can tap the amp and it will play again. also at low volumes or with everything muted the subs make a super high pitch sound (sometimes). i pulled it out today and as far as i can tell nothing is hurt in the amp but im no expert either. So if you have any help it would be greatly appreciated.
gain set well below "Normal" and base boost is off completely
15
185
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
386
6
483
brandonsgsxr
brandonsgsxr
Minden, LA
brandonsgsxr
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
