Amp and Bass Issue
  • 2
Darrenw77
CarAudio.com Newbie
Hi all
Really need some help here, I have a 54 plate Saab, it has the upgraded 7 speaker system, it has two factory amps that power these speakers. I have removed the rear speakers and spliced into the cables attaching a speaker to rca converter to the cables. When I tested the system I had no Bass. I started to check over and removing the right rca cable from the amp the speaker came alive. However it does not sound clear and on higher volume levels it starts clipping and popping. Ive double checked the wiring this is all fine. I have basic ICE install knowledge so not sure on where to go from here. with this year on Saabs they have a fiber optic system that you can not remove so I cannot remove or by pass Amp 2. Anyone have any suggestions on what my next steps should be? I have a digital multi tester so can carry out basic checks..
Any help would be most appreciated..
Darren
Hi all
Darren
Any time removing an RCA cable makes it louder you've got a polarity issue. I know you said wiring was correct, but it sounds like it's not. Double check that your reference for wire colors isn't wrong if nothing else.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
Darrenw77
CarAudio.com Newbie
Darrenw77
Kent, England
Lasherž
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
