Alt + to batt + starting issue
  • 2
SQBubble
MTL
So I did the big 3 , at first i only did batt to ground and ground to engine block and tried this for a week and it was running good. Then i went ahead and added 0 gauge from alt to batt and the car wouldnt start without revving it while starting... and at idles the rpm goes unconfortably low, shaking the whole car... as soon as i took the 0gauge off it went back to normal starting..
Im just curious to know whats happening? Is this an early symptom of a weak alt? Belt need to be changed? Is it prioritizibg the 0gauge wire when i put it and all the other components/engine arent getting enough juice ?
Thx for any insight
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
204
$500 is not unreasonable, but just know about alternator shopping: There are two numbers that matter: The amp output at or near idle (what's it...
7
875
SQBubble
SQBubble
MTL
SQBubble
