Alex's Silverado
U should just run one alt for trucks stock electronics and then the other three alts for the audio side seperate. That's what my buddy does in his 2011 tahoe. Works perfect
Right, that's exactly what i'm doing. I did the same thing when I ran the Wardens
ok, positive still needs to be switched so it doesn't drain batteries
Right, is my diagram I posted correct? You've obviously used these before. I just want to be sure before I hook them up
My alternator only had one "field", +12, and ground. Not sure about all that other stuff there.
My uncle Dave got some Goodyear slicks for his 57 Chevy rat rod. I loooooove these tires //content.invisioncic.com/y282845/emoticons/cuddle.gif.bd1b29c179c0482f8313dbd790b74c94.gif
He's giving me a 97 Silverado single cab, 350, and transmission to build my own rat rod! It'll be a project I work on for years in my spare time.
I load tested all 28 batteries from my truck. 26 tested great and two were "low", but not bad. I'm trading 20 of them and the 6 Soundrive subs I have left for a 2010 Suzuki rm-z250. I hauled 41 batteries with my 1500 //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
After hauling the batteries in to town, I removed the bed of my truck. I'm going to be welding the holes in my bed shut that I ran my power/ground wires through. Then I'm installing the flip kit I just ordered to drop the rear 6"
Screw photobucket, lol.
Just picked a DC 175.4 up local //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
643
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
9
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
ChaseinBass
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
