Aftermarket alternator with stock style battery ?
AshleyOU
CarAudio.com Newbie
15
Savannah
Looking at a mechman, singer, or DC alternator for my car. Planning audio system later this year. It will be a daily setup so not going crazy on the wattage.
My last setup I did Singer alt and replaced the battery with an AGM. I just replaced my stock battery a few months ago with a non AGM battery. Since the new alternator will greatly surpass the amperage I need is it okay to stick with Duralast battery I just bought ?
I know AGM are typically better for car audio but in my situation would it even matter much ?
should be fine if you are going to power your stereo with engine on. Otherwise if you forget and try to demo car off it will zap your battery pretty quick and regular lead acid aren’t meant to be drained down. Aka it may not recover.
Any other opinions on this ? It was my understanding that AGM is good for when you have to pull straight battery but should I technically be fine since my alternator will produce more power than what I plan on pulling ?
It should actually be better for the battery because the battery shouldn’t need to provide any current to the amplifier. If an amplifier draws more current than the alternator can supply the battery makes up the difference. Using a HO alternator should take a load off the battery which should help it actually last longer.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
710
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
890
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
AshleyOU
CarAudio.com Newbie
AshleyOU
Savannah
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
