Advice on adding a 2nd Battery
  • 3
Firewalker
CarAudio.com VIP
3,253
1,287
nowhere
Going to be adding in a 2nd battery for this new Cab-22 amplifier that will be shipped later on this week or early next week. So I am looking at adding in a small battery as well in back. Any suggestions on a smaller battery that will work? The Cab-22 is a 2k amplifier and I have the PPI i520.4 as well installed.
Been looking at the XS Power Batteries and a few others
Thanks guys
If you are running a multi batt setup and each batt is not the same, then they should be isolated from each other either by an isolator (don't recommend) or a relay (recommended).
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
556
It also lowers the amps efficiency and raises the current draw.
5
689
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
852
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
929
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
Firewalker
CarAudio.com VIP
Firewalker
nowhere
audioholic
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
