Add a tweeter or cross lower?
  • 3
Bwap
NY
I have recently constructed a pair of crossovers for my front stage.
The crossover point is 2750hz, butterworth, for both the mid and the tweet.
I feel that because the sensitivity is much higher on the 8" that there in quite and overlap at the crossover point. I am considering changing the low pass crossover on the 8" down to 2k. I don't know how this will pair with the tweeter, so I am asking you guys.
Even at about -10db at 5000hz, the 8" still overpowers the tweet..
I think it is the sensitivity difference, making them not pair nicely.
The speakers I am using are:
PowerBass 4XL-80-94 (4xl8094) 8" Competition Grade Composite
and
Morel MDT 12 1-1/8" Neodymium Tweeter 277-060
Both sound amazing, I just don't know where to cross them to sound nice together.
I was told 2750 would be fine, but there is definitely an overlapping issue.
This is how they are wired, ignore the supertweeter.
Youre using a relatively loud 6" midrange with a tweeter that was never designed to be used in a car, and never designed to be loud. Buy a set of bullet tweeters and you will have that extra high end that you need.
Edit: Just saw the Morels were 8ohm. Try running a set of these. Should work just fine. Just fine for a small setup.
Selenium ST200 Super Tweeter 264-348
My problem is actually the overlap 3k+, Was planning on adding a supertweeter until I noticed how rough an overlap is.
The morel sounds great, its just that the 8" screams the highs louder. I would rather the 8 play less highs, than add more to the higher end.
Im considering a 2k linkwits to see if it crosses better, as it is -6db at 3k and -12 at 4k.. it will slope harder, making the highs on the 8 fall off while the tweet is unaffected.
Anyone have any input?
It would be nice to have some help solving this, as I was recommended from people on here where to cross at and against my better judgment went with it.. now I have the huge overlap.
Even if the 8 only plays to 2-3khz, its still going to be much louder than the tweeter. The tweeter isnt designed for a situation like that.
Get a product that is.
Passive crossovers have limitations and you've discovered one of them. The 8" mid might not be 4 ohms at the frequency you're trying to lowpass it. That plus the sensitivity differences and driver mounting locations (on/off axis etc) make it hard to dial a homemade passive system in without a lot of trial and error.
At this point maybe you should consider an active solution where you can set the crossovers and speaker levels separately with just a twist of a knob. There are some nice 4 channel amps at reasonable cost that can do that for you.
Already running 3 amps, these front speakers are being ran at about 240 watts from two channels of my rock four channel. so a channel per driver isn't an option.
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
3K
I took a quick look at the manual for the Jensen. It only says that the usb is compatible with memory sticks and iPhone and iPod. It makes no...
Bwap
Bwap
NY
Bwap
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
