Active or Passive Setup
Greenwing6
I've lurked for a long time and now new truck equals new upgrades and a "what would you do" for those that know alot more than I do...
Would you go active or passive? Here's what I have...(going in a crew cab F250)
Rockford fosgate power 6.5" Front components (100w RMS)
Rockford fosgate punch 6.5 coax for the rear (55w RMS)
Rockford P3 shallow 10 sub (300w RMS)
Kenwood Excelon x801-5 amp (50x4@ 4 ohms/ 300x1@ 4 ohms)
Using Pac amp pro for the sony system in 2018 F250 so the option is there to let the rear speakers be powered by the stock amp as fill if going active. Passive would be a super easy install with the PAC harness. What would you do????
Thanks guys!
Thanks for the input! I personally dont care about rear fill and would focus on the front stage, but end up taking longer trips with the family so I need something there. Might just add a small 2 channel for the rears.
id bridge your amp and run the fronts passive off it, and run the coaxials off the deck
unless you are going to buy a more powerful amp, then bridge it and go passive and run the rears off the factory.  If you get another 4 channel amp, get something with 120+ per channel and run the front stage active.  then run the rears and the sub off your kenwood amp.
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
773
10
565
10
955
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
So, assuming that you aren't using an LOC and are using the hi-level (speaker) inputs, use the speaker leads off of any of the R/L speakers (front...
39
4K
Greenwing6
Greenwing6
Justin Garrett
    May 18, 2024
    May 18, 2024
