Accidentally disconnected a subs now every speaker and sub connected to amp is popping/clicking really loud
  • 2
Soundjunkie2008
CarAudio.com Newbie
First post here
So a few weeks back i picked up a decent-ish setup...
2 Pioneer A300D4 DVC 12inch 4ohm subs
1 Targa Thump 4100.4 4channel 4900watt amp
And a Pioneer deh-s1150ub headunit
Broke the subs in with about 50hrs of playtime, the the unthinkable happened, i assume because of the vibration one sub's wiring accidentally disconnected and i heard a loup thumping of the subs, so i turned everything off, connected the wiring back again, but now when i plug an audio source like my phone or a usb into the headunit (its controllable by a Pioneer ARC app) or do anything that triggers the amp to turn on, both my 6x9's and subs make a really loud clicking and clipping popping whatever u wanna call it, and an even louder thumping when i disconnect an audio source and the amp turns off, and i dont hear any music just surging sounds, plz help
Sounds like a ‘ground loop’ problem. I am going to guess that when the speaker wire came loose it shorted against the amplifier’s case.
long story short, you have damaged the amplifier. If you are really unlucky, you damaged the head unit too.
Did you get the amp new? Does it have any warranty?
Yes sir I did get the amp new, looks like I have warranty on my side, and I don't think the head unit is damaged at all, it still operates completely normal, both the front 6inch speakers are connected to the head unit, subs and 6x9's are at the amp, and now I've connected all the speaker wire but left the rca's disconnected, and now when I plug any 6x9 or sub into the amp's input side it does all that, but the speakers that are connected to the head unit still plays fine. Thanks for your help!
I have Pioneer deh x4850bt and im not using any loc or dsp just an rca from the head unit
17
4K
I connect my Amazon Echo Auto (Version 1 and now the new Version 2) to my Sony MEX-GS810BH via Bluetooth and set the MEX to Bluetooth Audio to...
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
Soundjunkie2008
CarAudio.com Newbie
Soundjunkie2008
South Africa
Soundjunkie2008
