Accessory Ignition Wiring Question
  • 2
Scott Brown
CarAudio.com Newbie
I'm in the process of installing an aftermarket stereo in my 2004 Chevy Trailblazer. I'm at the point of soldering up the wiring harness and I'm stuck. I don't know what to do with the 10' long red wire that came in the harness package. Both sides of the harness had matching red wires coming out of their plug housings... I soldered those together. So do I need to do anything else? The new unit is simply a swap for the old, so I would think the receiver would turn on and off when the power's started and cut, just like the the radio that preceded it. Finally, since the location of the new unit is the same both physically and... uh, electrically... is the new stereo fuse-protected like the old one was?
Thank you for taking a few moments to answer my questions. I really didn't know anyone else to ask.
Sincerely,
Scott
yes, red is usually the ignition/accessory wire, it needs to be connected from the factory harness to the one for the new head unit.
Yes, there will be a factory fuse that would protect the head unit. usually under the hood or under the dash. Also a lot of head units have a fuse on the back of the head unit.
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
886
I did yeah. The OEM Harness was frustrating because the pinouts for the aftermarkets had the wrong layout. I have it correct. I'm measuring low...
5
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
8
Thanks for the clarification. Fuse boxes generally have some blank spots you can tap into.
6
Scott Brown
CarAudio.com Newbie
Scott Brown
Wilmington, DE
dangerdan86
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
