about enough juice.
  • 3
wrong....the xtra batt. is for when your car is off...thats the only advantage you'd get from it.....while your car is on a larger alt is the only way to truely able to get the extra power....
so let me get this straight the only reason you would get a battery is so you can just run straight audio and stuff of that nature? It's worth it cause to me i'd rather have a car driving then being stuck on the side of the road cause you don't have enough juice to go anywhere.
the alternator is what keeps your battery charged and basically distributes power to all your electrical system. With this in mind, you could get a new alternator that puts out more amps with the same battery...this way your electrical system will run stronger because there is more current running to it.
agreed....basicly if your alt isnt up to par...it wont matter how many batts. you have....it may take a little longer for them to go dead but they will go dead over time....and will also put a larger strain on your alternator....good luck
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
rouskisman
rouskisman
Greenville, South Carolina
MikeofTulsa
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
