? about 2007 Accord deck install
  • 3
nauc
216
USA
my buddy has a Kenwood deck he wants to put in using this...
Honda Accord Kit 2003-up, chassis size E at Crutchfield.com
his dash looks like this....
but how does that work tho, will it bypass the stock deck functions etc
thanks
This isn't a help, sorry, just wanted to say best of luck. I said screw it and used a cleansweep. Try driveaccord.net forums if you don't get any help here.
I had a 2007 Accord and IIRC they will give you a harness that will allow the stock radio to control the climate controls but you will have to wire in the speakers and what not.
Also, the kit that replaces the climate controls ****** balls in 2007 because it would require that you turn the car off and start it again to get your climate controls working. It was a horrible hack job that cost a fortune for the functionality that it screwed up. Then again, that could have changed since my Accord met an untimely death via drunk driver after 8 months of ownership in 2007. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
did you have this kit, cause it doesnt replace the climate controls. the kit sits below the climate controls. it replaces the cd changer and storage spot thats under the changer
bump
I had the kit that replaced the climate controls and it was a huge POS. When it worked, about 10% of the time, everything was golden BUT when it stopped working, I had to restart the car to get AC again.
I actually put the stock radio back in and was going to go with the kit in your photo. Unfortunately a drunk driver changed my audio plans for that car. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
got it, thanks
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
6
965
Based on the age of your system, it may be a good idea to look for a new aftermarket unit.
4
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
nauc
nauc
USA
nauc
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
