A very noob HU wiring question.
  • 3
greyhnd
Hello folks. Acouple quick and easy questions about wiring a new HU.
Vehicle - 96 Jeep Grand Cherokee. Originally equipped with the Infinity Gold system, but that is going bye bye with the new system install.
I'm using a JVC KD-R530 HU, MB Quart Discus DSC-450 Amp, MB Quart PVI26 Components and a Sub to be added later.
I'm running all new speaker wire from doors to amp, so I won't need to use any of the factory speaker wiring. RCA's from HU to amp for signal along with the remote amp turn on.
When I wire the new HU, I only need to be concerned with my power(red), battery(yellow) , grnd(black) and remote turn on(blue/white), correct? No need to wire the speaker connections into the aftermarket wiring connectors?
I think I'm over thinking the whole process.
CrossoverOre - Thank you for getting my mind set right. I was sure had no need to connect the factory wires since the RCA's are being used, but I have a tendency to talk myself out of the correct choice. Thanks again for the quick and simple answer.
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
greyhnd
greyhnd
Huntingburg, IN
SplAffair
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
