a lot of b/n woofers for sale, mostly old school
  • 6
nudels
KNOCK-KNOCK!, MOFAKOO!
1. (3) bnib aura 12000 rpm's (12")
2. (3) bnib hollywood soundlabs hsl 125d's (12")
3. bnib rainbow hammer (12")
4. bnib arc audio 8d4 (8")
5. bnib volcano xk2 cannibal 12c (12")
6. (2) universal electronics 'black max' ues-804, (8") one sagging from being inverted for 10 years
7. (4) bnib pinnacle 8" poly woofers
8. b/n clif designs 12"
9. b/n clif designs poly 10"
10. b/n sunrise speakers 12"
11. b/n m&m godfather 10-4 (10")
(lots more to add, still)
all b/n, tested for proper sound/operation is the furthest these have been powered
1. (each) 2" single 4ohm, 250w rms, semi-transparent poly cone, santoprene surround, bbp (bumped back plate) fs-24hz, qts-0.53, vas-6.0cuft, mounting depth-5.125", cutout dia.-11", driver displacement-0.06cuft
2. (each) 2" dual 6ohm, 200w rms, poly cone/dustcap, foam surround, 'mag. flux optimizing structure ('mafos') design, bbp, fs-26.7hz, qts-0.64, vas-6.3cuft, 88.6db @1w/1m
3. 2.5" dual 2ohm, 400w rms, poly cone/dustcap, santoprene surround, cast basket, bbp, fs-28hz, qes-0.34, qts-0.32, Le-3.21mH, vas-60L, Sd-510sqcm, Xmax-23mm, driver displacement-4.3L
4. dual 4 ohm, 150w rms, poly cone/dustcap, santoprene surround, fs-24.7hz, qes-.367, qms-3.572, qts-.332, vas-1.55cuft, Xmax-15mm one way linear, Sd-231sqcm, 85.6dB@1w/1m
5. 2.5" single 4ohm, 3-400w rms, high density paper cone, poly foam surround, 8 spoke cast basket, bbp, fs-34.7hz, qts-0.54, vas-2.7cuft, 94dB@1w/1m, oem'd by stanford acoustics
6. (each) 2.0" vented single 4 ohm, bbp, 125w rms, fs-37hz, freq range-30hz to 3.5khz, qes-0.45, qms-3.84, qts-0.40, Re-3.4ohm, vas-39.39L, 92dB@1w/1m
7. (each) 2.0" single 8ohm, poly dustcap/cone, butyl surround, bbp, 30oz mags,
Re-6.0264 ohm, Fs-29.0347 Hz, Zmax-57.2313 ohms, Qes-0.2905, Qms-2.4681, Qts-0.2599, Le-3.0598 mH (at 1 kHz), Diam-168.2750 mm (6.6250 in), Sd-22239.7074 mm^2( 34.4716 in^2), Vas-42.5656 L (1.5032 ft^3), BL-13.7012 N/A, Mms-49.5988 g, Cms-605.8093 uM/N, Kms-1650.6844 N/M, Rms-3.6661 R mechanical, Efficiency-0.3370 %, 87.2945 dB @1W/1m
8. 2" single 4ohm, graphite injected reinforced pulp cone, poly dustcap, butyl surround, bbp,.. not much info on this, can pull t/s parameters upon request
9. 2" single 4 ohm, poly cone/dustcap, foam surround, bbp,.. same as the 12", can pull tsp's upon request
10. 2" single 4 ohm, rigid 7 rib paper surround, poly dustcap, santoprene surround, 4spoke cast basket, dual slug motor structure,.. again, not much known about this driver other than it seems to be built quite well for a sq application
11. THE very last m&m godfather 10" to leave gefco speaker manufacturing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif, 1.5" single 4 ohm, foam surround, reinforced paper cone, bbp,..
Re = 3.6979 ohms
Fs = 28.2472 Hz
Zmax = 26.5664 ohms
Qes = 0.5084
Qms = 3.1442
Qts = 0.4377
Le = 0.8358 mH (at 1 kHz)
Diam = 206.3750 mm ( 8.1250 in )
Sd =33450.6109 mm^2( 51.8486 in^2)
Vas = 106.1968 L ( 3.7503 ft^3)
BL = 7.8319 N/A
Mms = 47.5173 g
Cms = 668.0958 uM/N
Kms = 1496.7913 N/M
Rms = 2.6822 R mechanical
Efficiency = 0.4423 %
Sensitivity= 88.4755 dB @1W/1m
Sensitivity= 91.8269 dB @2.83Vrms/1m
all prices are without shipping
1. $40 each, $100/3
2. $40 each, $100/3
3. $150
4. $70
5. $130
6. $40/pr
7. $30 each, 100/all 4
8. $45
9. $35
10. $75
11. $150 firm
everything gets insured and diligently packed
View attachment 26537507View attachment 26537508View attachment 26537509View attachment 26537510View attachment 26537511View attachment 26537512View attachment 26537513
adding a b/n pair of aura force 10's (boxes not pictured), 130+shipping or possible trade.
killer clarity-geared subs, i have a few ill be using in which these were intended to be replacements for in case i break/fry one or 2, but i have enough on-hand to part with a pair.
these feature alum alloy cones, butyl surround, cast aluminum vented aura baskets, 5-way gold plated binding posts, heavy gauge insulated tinsel leads
factory specs and rec. enclosures;
fs- 27hz
qts.- 0.37
vas- 2.21cuft
driver displacement- 0.04cuft
thermal power handling- 200 wrms (free-air)
recommended amplifier output power- 50 to 400 wrms
mounting depth- 5 inches
cutout dia.- 9 inches
min/recommended sealed encl. volume- 0.65/0.9cuft
recommended ported encl. (with poly-fill)- 1.2cuft w/a 3" dia. port-10" long
the following t/s specs are pre break-in;
Re = 3.3370 ohms
Fs = 28.5065 Hz
Zmax = 54.6712 ohms
Qes = 0.4625
Qms = 7.1148
Qts = 0.4343
Le = 1.0592 mH (at 1 kHz)
Diam = 209.5500 mm ( 8.2500 in )
Sd =34487.7765 mm^2( 53.4562 in^2)
Vas = 66.4869 L ( 2.3480 ft^3)
BL = 10.1179 N/A
Mms = 79.2156 g
Cms = 393.4970 uM/N
Kms = 2541.3154 N/M
Rms = 1.9942 R mechanical
Efficiency = 0.3129 %
Sensitivity= 86.9721 dB @1W/1m
Sensitivity= 90.7694 dB @2.83Vrms/1m
Krm = 1.667E-03 ohms Freq dependent resistance
Erm = 831.263E-03 Rem=Krm*(2*pi*f)^Erm
Kxm = 17.473E-03 Henries Freq dependent reactance
Exm = 663.545E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 24.278 Hz
Ftest/Fms = 0.8517
Test Mass used = 30.0000 g (Equal to 6.0 nickels)
Test Mass (Ft=Fms*0.90) = 18.581 g (Add -11.419g for Ft=25.656)
Test Mass (Ft=Fms*0.75) = 61.612 g (Add 31.612g for Ft=21.380)
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
I can hold a conversation with you and never hear a damn thing you say.
5
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
nudels
nudels
right here
nudels
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
