a few questions
  • 2
Damian Romero
ok i got an rockford punch 325.1 and a kicker L5 10 (comes in the kicker truck box), first question, is it better to put the box behind a seat facing foward, in the middle, or facing backwards (i got a single cab 2005 f150)
ok the amp does 386 @ 2 ohm, and 1100 max power (thats what it said on the paper)
ok i set the gains to 27.8 volts ac (according to the calculator), and now its fine on the 50hz bass tone...but i left it hooked up and lpayed a few songs (mainly bass) and it never goes pass 15 volts...and its kinda quiet, just wondering if its safe to turn the gain up a little bit more (i played about 30 diffrent sogns and only a few got up to the 20s for volts)
did i set the gain correctly?, also what is so evil about the bass boost knobs
it calls for 27.8 volts when setting gains...lets say on one or two songs it goes to 28 or 29 volts...will that hurt my amp?
and just to make sure, to wire a 2 ohm sub to a 2 ohm amp, just put + to + and - to - on the same side of the amp, right?
thanks for the help
thanks for the help
bass boost knob causes distortion and most songs don't have 0db tones in them which is why your voltage dropped
so would it be better to go ahead and set my gain by going off of a bunch of songs?
also what about my other questions
thanks man!
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
490
Damian Romero
Damian Romero
Louisiana
Damian Romero
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
