a couple of quick big 3 ?'s please
  • 4
mm0142
CEO
439
Waco, Tx
im usung 1/0ga now if the power wireis only 2ftdo ineed the anl fuze also is it safe to use the alternatorbracket boltfor the block mounted ground or should i run the 4ft wire like the factory wire . im leaving all the factory wires also if this helps
yes you need a fuse and try to make it as short of a distance as possible . as far as the alt bracket as a ground im not really sure its a good idea but its what i did and i haven't had a problem
ok will do i wentahead andbought a 1ga battery wire at auto zone for the power wire and it was made to go from the battery to the alt. butthey had told me you only needed a fuse if it was over 2 ft . ihave an extra anl holder and 300a fuse ill hookit up to the wire justwanted to make sure i need ed it . imgonnado my big 3 in 1/0ga and the amp wires in 1/0ga also . ill take pics andpost it all up its a alpine 9885 hu , sundown sae1200d and 2- 12" re se ina 2cuft sealed box . just wanted to get it all hooked up right the first time .
Thats what im using it even says GND on it:D
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
7
953
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
mm0142
CEO
mm0142
Waco, Tx
tv559
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
