I have a 2000 malibu, and if it's the same, all you have to do is:
1. pull out the black trim piece. don't worry, just pull on it; the thing over the key socket will fall off too.
2. then all you gotta do is remove those two screws, pull out the radio, and disconnect the wires
%0message=I have a 2000 malibu, and if it's the same, all you have to do is:
then to put it back on just put the key socket thing inside the trim, and press the trim back into place.
