8-pack of mids - $40 shipped
  • 4
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
Email me at Ryan@RAM-Designs.com if interested....I do not respond to PM's, and may take a while to respond to posts. Email is definitely the best way to get a hold of me.
Sony 5.25" shielded neo mids.
Brand new, never used or mounted.
This Sony neodymium woofer features an attractive, high quality treated paper cone, high-excursion flat spider, and extended pole piece for improved bass response. It is recommended for use in surround speakers, mini monitors, or compact multi-way systems, as well as being an ideal candidate for line array designs. Magnetically shielded.
Specifications:
*Power handling: 20 watts RMS/40 watts max
*VCdia: 1"
*Le: 1.52 mH
*Impedance: 8 ohms
*Re: 7.71 ohms
*Frequency response: 80-6,000 Hz
*Fs: 81 Hz
*SPL: 85.3 dB 1W/1m
*Vas: 0.16 cu. ft.
*Qms: 7.81
*Qes: 1.10
*Qts: 0.96
*Xmax: 3 mm
*Dimensions: Outside Diameter: 6-7/16", 5-1/4" across flats, Cutout Diameter: 4-7/8", Depth: 2-1/2".
8 for $40 shipped, will only sell in multiples of 8.
16 = $80 shipped
24 = $110 shipped
Included in price.
Got a graph of em? And how many ya got? For a l=nice line array I be thinking you need 8 per side.
No graph, but they have good reviews from others from what I have seen. I assume with some minor EQ they can be made pretty flat, like most any other speaker. I have quite a few...8 per side is the minimum I'd do if you were wanting to do an array.
how much power do you think these can really take if they are cut off at 100hz?
100hz, not a whole lot more than rated(rated power is playing full range). But if you use some dedicated 8-10" mids/subs and cross these at ~250hz with at least a 12db slope, I imagine they can get really loud when put in groups and stay clean since they won't be playing much bass/midbass. I'm sure EQing a few bands will be able to yield some nice results.
I am going to install my Kenwood KMM-X705 Excelon head unit and a set of Infiniti Reference 6.5 mids and tweets in the front. I have a pair of...
https://batteryhookup.com/products/super-beast-module-with-48-headway-38120-hp-3-2v-8ah-24v
23
7K
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
8
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
silvercookie
