8 component sets, 1 4 channel amp
  • 4
RodSlinger
CarAudio.com Newbie
Gentlemen, I have a question.
I am dumping my Focal FDP 600.4. It still works, as does the Focal FDP 900.1. As with anyone with a lack of hearing because of music, I want louder. I have 2 Focal EK 30 12” subs wired to 1Ohm to the FDP 900.1. I get good bass, but believe I could get more.
Ive made a much smaller investment in 8 Massive Audio FZ6 6.5” 4 Ohm 200W RMS/ 400W Peak, component sets.
Focal Subs are dual 4 ohm VC 800W RMS/1600 Peak I’m keeping.
Anyway…. I’ve stumbled upon an issue I need some guidance with.
I’d like to replace the FDP900.1 and the FDP600.4 with MORE.
Question is, can I run all 8 component sets from one good 4 channel amp or should I buy 2 good 4 channel amps? The wiring is in place for either installation. Problem is I’m having trouble finding a powerful amp(s) that will power all the components at 4 Ohms.
Amp suggestions? Wiring suggestions?
Thanks
Your first step is going to be getting another amp. 2 of the same multichannel would be a good start. Do you have a DSP?
I’ve got two matched Stetsom 1200.4’s, the Focal 600.4, and the Focal 900.1.
I have been searching for an affordable DSP. Interested in the AudioControl DQDX, I believe is the model. 6 in, 8 out. $600 price tag is killing me. Suggestions?
Thanks
If you are wanting to run @4ohms be best to go with 2)- decent 4 ch amplifiers In my opinion. Running @2ohms yo can prob get away with a nice single 4 ch maybe for all the components. I would think that you will have to consider rebuilding/ configuring your sub stage to keep up with the new 8 components setup to even things out
Components= 200rms per side
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=154594911994
This amp come to what Id prob, go with for front stage.
Sub amplifier maybe a Gladden be nice
https://www.gladen.com/GladenAmpPDFs/SPL_1800c1.pdf
Maybe look at another RF 2k mono to match or look at some Zapco amps?
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
I ended up going with the Infinity Reference 6.5 component set up front, and polk audio dB 522 coaxial set in the rear. All of them powered by a...
29
3K
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
RodSlinger
CarAudio.com Newbie
RodSlinger
Tallahassee, FL
