6x9's In Need!
  • 4
Just upgraded my head unit to a Pioneer AVH-4100NEX and it has a 50W x 4 (14W RMS) speaker outputs. I currently have the stock speakers and they definitely sound a lot better after the head unit but they are blown out.
I've heard that under powering or over powering your speakers isn't good but what are some 6x9 speakers that I can turn up the volume and wont have to worry about distortion? Possibly looking to get a 4ch amp later down the line.
Unless the speakers were old and very worn before the 4100NEX went in it was likely user error that led to them blowing out. Go back into your audio settings and turn down the EQ, the bass boost, and leave Loudness off. You probably should have SLA turned off as well. New 6x9s will probably sound a lot better on head unit power, but if you do have your settings cranked up to make the stock speakers sound louder you need to break that habit now.
Well on the old head unit it was noticeable that some of the speakers were blown out even at less than half volume. It was a rental car before I got it. The EQ is flat and bass boost isn't on at all. Do you have any 6x9 recommendations?
What's the car? Year, make and model.
There is no such thing as underpowering a speaker. You cant hurt a speaker giving it only 20rms instead of 60.
Over powering a speaker can be an issue but most the time. You can give speakers a good amount over their rms rating and they will take it, If its a clean signal.
Distortion happens when you turn up your head unit to max and it starts clipping. What you need is an amplifier. That will give you the volume your looking for with no distortion/clipping.
Precision Power PPI P600.2 Phantom 2-Channel Car Amplifier
Why Too Little Power will NOT blow Your Speakers
I have an extra pair of these, NIB, $100 shipped!
14
3K
Excellent!! Looks to be in tact. It will be a workhorse for you man
40
5K
Might be time to try something new as it sounds like it is the limitaion of the speakers. I’m not in the habit of recommending JBL but a buddy of...
40
5K
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
If the JLs are not entry level, then do not torture yourself, just go for it. You already enjoyed those DS18s. In case you do not like them, the...
homeboy8181
homeboy8181
Los Angeles, CA
mclerico83
