6x9 suggestions and running 3 ohm speakers
  • 1
Gemcoska
Here's what I'm trying to do:
Run eight (8) 6x9s speakers of 1 4 channel amp. I have my reasons.
The amp:
Powerbass XAX-4160
PowerBass Xtreme XAX 4160FD 4-Channel Full Range Class D Mini Amplifier | PowerBass USA
Full Range Class D amp
4 channels
100Wx4 @ 4 ohms
160Wx4 @ 2 ohms
I'm looking for some 6x9's now that i can run in parallel, 2 per channel.
The power bass L-6903x (100w rms) looks like a good option, but its 3 ohms. I would prefer these if i could run 8 of them at 1.5 ohms on 1 XAX amp
PowerBass Autosound L-6903x Full Range | PowerBass USA
The cadence speakers look pretty good also
The CS3.69 is a safe option with a rating of 175 rms
Cadence Acoustics Momentum Series CS3.69, 6" x 9" Three-Way 700 Watt Speaker System
I would prefer the XS694 (4-way) but its rating is only 75w rms. The XAX pushes out 100W (4ohms) 160w (2ohms). So theres a good chance i'd blow these puppies.
Cadence Acoustics Xenith Series XS694, 6" x 9" 250 Watt Four-Way Coax Speaker System
Maybe someone with some expertise can give a more detailed answer on running a 1.5 ohm load on the XAX amp? Or suggest a better 6x9. The one above ranger from $50 to $70 a pair.
I have an extra pair of these, NIB, $100 shipped!
14
3K
Excellent!! Looks to be in tact. It will be a workhorse for you man
40
5K
Might be time to try something new as it sounds like it is the limitaion of the speakers. I’m not in the habit of recommending JBL but a buddy of...
40
5K
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
If the JLs are not entry level, then do not torture yourself, just go for it. You already enjoyed those DS18s. In case you do not like them, the...
Gemcoska
Gemcoska
Los Angeles, CA
Gemcoska
Decebal
    Jun 10, 2024
