6.5" comp set advice
lawlyes2007
I have an 04 mazda 6 with the bose system currently. I have an REaudio SE15 with a jl 500/1v2 in the trunk. Its time to upgrade the front stage lookin in the $300 range for amp and components. I'm lookin at the morel maximos and the ID CTX65cs. I also remember reading on here many people praising the Pheonix Gold RSD, how much better are the ID or Morels vs the RSD?? I havent yet picked out an amp for this setup so I need recommendations.
this...or if you wanna go 2 way, look into Hybrid Audio or Boston Acoustics or check the used classifieds here on the site
dragon- the $300 is for components and an amp.
I really wanna stick with 2 way, I dont feel like cutting any of my door panel.
The woofer is in the door and the tweet will be in the door sail?
Dont the HATs need the tweet and woofer to be close otherwise they are harsh??
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
534
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
289
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
722
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
805
lawlyes2007
lawlyes2007
Champaign, IL
Wasatch
    May 24, 2024
    May 23, 2024
