.5 ohm load
for burps you can take them below .25talk to louisiana_crx he has burped his Z1a's around .167 if i remember right. or right around there
I seen M3s personally run at .25 and 10v daily...still playing //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I argued with a "board expert"on this forum call me a liar for saying m3's are used a lot for 1/8m ohm burps. But thats why they used to be a usaci standard. Rated at 600 watts 4 ohms and then they burp them at 1/8 in the 0-600 stock class.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
173
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
830
Burp09
Burp09
meridian, ms
Burp09
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
