4th order with 2515s
  • 2
slvrado28z
midland, tx
I have 4 dd 2515s in a 4th order but its not hitting the lows like it should. I bought the box used with subs already in there. I think the box is a lil small with 1:1 ratio.. is there a way I can redo the port to make it hit the lows or do I need a new box? It hits 38-45 loud but lower than that not so loud.
redoing the port really wont help you. Adjustment to the port, usually going larger will make it louder but you would still have the same issue of not being able to produce low notes. Your sealed side is really what gives you the ability to hit low notes. I would redo the box and increase your sealed side.
The thing with 4th order is trial and error. I would have it modeled and they start playing with it. You gain low end on a 4th by the sealed side. you said the orginial box was a 1:1 ratio which I have seen. I think I even have a design I got years ago that was very close to 1:1. Most of the designs I see like that are usually for someone trying to achieve a flat response, more SQ. The design I had by memory was something like 3 to 5 db louder than the same woofer in a sealed box. Its also been years but I thought the 2500 series was the DD subs that liked 4th so you should be ok there. I know other DD models were not 4th order friendly but other may chime in if I am incorrect.
It has a flat response I just know these subs could get louder you know any builders that's could design me a new box
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
4
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
7
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
slvrado28z
slvrado28z
midland, tx
slvrado28z
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
