4 sub's, having a problem with 2
  • 2
beartoe
I have four kicker comps on 2 900 watt 2 channel amps. I have them split off one power wire with a dist block. Two of them work fine on one of the amps. On the second amp, when one sub is connected, that one sub works fine but when I hook up the second sub on the second amp, both subs move but put out no bass. I have tried bridging the amp as well as running them in parallel but it does the same thing. Is there something wrong with the wires or amp or subs? The second amp is new and so are the sub's connected to it. Any help with this issue would be greatly appreciated.
438
461
568
695
beartoe
beartoe
Baton Rouge,LA
beartoe
    Jun 1, 2024
    May 31, 2024
