4 channel crunch. 3 rockford p3's
Where in the Hell did you even get max. ratings for that amp at 2400. And this 3 rockford p3 4/2dvc still doesn't tell anyone what they are VC wise, either dual 2's or dual 4's? Can't be both.
That amp has 2 30 amp fuses. Most you're going to get bridged might 700-800. Probably more like 200 X 2 bridged at 4. So not really enough. And you can't get to 4 ohm with the dual 4's. You could do .5 ohm or 2 ohm. Sorry bud. If you already have both the subs and the amp I'd get a bigger mono to power the subs. And get some door speakers you can power with the Crunch. Or start over altogether....
Crunch is false advertising??
Yes, most low end companies use "MAX" power ratings to advertise their amplifiers, they are nothing more than a random number chosen to attract attention, RMS power is a true power rating, and is what you'll be likely to see under some conditions.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
96
6
344
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
727
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
428
mobass
mobass
Brooklyn
mobass
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
