4 channel amp
  • 3
What are you really looking for from your system? What are you trying to get besides just a bigger watt rating from your amplifier? Maybe I've failed to address these questions with you, because when I talked to you about the P900.4 I didn't really consider that you may already have a good amplifier. 90W per channel is miles better than head unit power, and while more power is good, you eventually run into some major limitations. These limitations include overpowering your speakers, which leads to power compression and overheating, exceeding the mechanical limits of the speakers, and needlessly drawing more current from your charging system.
I do appreciate your help Trumpet, I have the pbr300x4 powering my doors 125w per speaker, i am in need of another amp to power my tweeters and get rid of the stock tweeters. I am thinking of using the current PBR and use that for the tweeter and get a more powerful amp to match with the 125w per speaker on my doors. I'm thinking of just getting another PBR priced around $140, so i am asking For price of under $150 priced new what other amp is considerably more powerful than Rockford PBR 300x4, the one i have has a birth sheet of 91watts per channel.
I have looked high and low and could not find any.
what makes you think you need close to that amount of power for some tweeters? Unless you're running a bunch of supertweeters then "maybe" you might...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
413
6
494
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
867
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
901
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
naughtyca
naughtyca
Tampa FL
mlstrass
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
