4 channel amp+mono amp - only 2 RCA outputs
johnniz13
Norway
Hi.
I`m seeking help within this forum and hopefully will get some input regarding the "best" method for connecting 6 RCA cables into 4 outputs. Hopefully the pictures I crafted (in a masterful manner lol) will explain it:
View attachment 26553217View attachment 26553218
Diagram 1 (on the left) is how I imagined it myself
Diagram 2 (on the right) is a "how to" video on youtube ca 07:55 into the video (
What method, if not another I haven`t though of is the "Best" one, I know none of them are ideal.
Thanks!
Buy 2 single male dual female y connectors and run them off the back of the rear/sub output on the deck that way you're still getting your front and rear fade on the 4 channel and getting left and right on the amp the way the video says to do it to me seems like it would lose quality
Sent from my HUAWEI Y536A1 using Tapatalk
Ok so you suggest running the y splitters out from the rear/sub outputs on the deck instead of front?
I have read somewhere that you loose voltage when using y splitters, and was thinking if the sub probably needs more voltage than the other speakers?
Yeah, that's why I seek help at this forum //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
Also, what gauge power wire would you guys recommend for two small amps? The 4 channel is 500W (160RMS) and the two channel bridged is 240W (120RMS). I'm planning on running one power wire into a distribution block, and was wondering if 4 gauge would be preferred to 8 gauge, even with that low wattage's.
I know it is recommended to use same gauge power wire and ground wire, but I have seen people run 4 gauge from the battery and 2x8 gauge from the distribution block.
Yes I suggest running them off the back of the deck imo makes for a cleaner install and you keep the audio phasing right
8guage is fine up to 500watt RMS if you wanna be safe run 4 guage to the distribution block and 8guage from the block to the amp do the same for the ground.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
406
6
491
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
862
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
490
johnniz13
johnniz13
Norway
johnniz13
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
